2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
SGS suspension
Old 07-27-2014, 03:47 PM
2014streetglide's Avatar
2014streetglide
2014streetglide is offline
Default SGS suspension
I am under the impression that the SGS rear suspension in 11 1/2". This is what I've been told by numerous dealers. Yesterday day I had my bags off, so I measured. 12" eye to eye. I thought I might have been doing something wrong. So I got my friend who was there with me to measure it. Again 12" eye to eye. I know they are the new adjustable suspension harley made. So am I getting bum info about the shocks supposedly being 11 1/2"? I'm asking cause I need to lower the bike to get my feet more flat footed and I know where I can get some progressive 944's 11 1/2" for a decent price. Thanks for any info you guys can give.
Old 07-27-2014, 04:46 PM
Webo's Avatar
Webo
Webo is offline
The shocks are 12" on the Street Glides. You might look at a different seat to lower you, they ware usually lower and narrower so it's easier to get your feet on the ground. If you lower it with the suspension it's most likely to ride stiffer than it does now.
Old 07-27-2014, 07:59 PM
Rustrtal's Avatar
Rustrtal
Rustrtal is offline
Front forks have about 3/4" of lowering adjustment in them. Try that before buying anything.
Old 07-27-2014, 08:05 PM
2014streetglide
How do you lower the front forks? I haven't been able to grab a service manual yet. Would that be in there?
Old 07-27-2014, 08:29 PM
2014streetglide
Are the burly and progressive shocks really that bad? It's hard to believe that they'd be any stiffer than the stock shocks?
Old 07-28-2014, 12:10 AM
TXCobra's Avatar
TXCobra
TXCobra is offline
I have the Burly Slammer rear shocks on mine. Had them on my '13 too and swapped them onto my '14. Stock was 12" and Burly's are 10.5"....worked great.
Old 07-28-2014, 02:38 AM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
The stockers are 12".
You can look them up in the HD parts book.... but apparently your dealers can't.
Old 07-28-2014, 04:53 AM
Rustrtal's Avatar
Rustrtal
Rustrtal is offline
Loosen the bolts in the tree, slide the fork tubes up and re-tighten. I haven't done it but have read about it here several times.
Old 07-28-2014, 05:28 AM
FastHarley's Avatar
FastHarley
FastHarley is offline
Former Sponsor
FYI under no circumstances do this. I have taken a fork apart and measured it along with the stroke. Your fork sliders will hit the screws that hold the cow bells on. The screws only protrude around 1/8" (estimated) but that is enough. By raising your fork tubes up 0.350" (fork cap above the triple tree), as one dealer did on a brand new FLHR, the sliders will hit. I would suggest that all measure first before doing the doing and know what you are doing. If you loosen and move your forks up into the trees this will happen:
Old 07-28-2014, 07:43 AM
2014streetglide
Thanks for all the info on the trees! I don't think I'll be going that route. Txcobra, do you bottom out? I had sent burley an email asking about their shocks. Their reply was the street glide has 11 1/2" shock and I'd be lowering it to 10" and I'd bottom out and rub the tire.
Quick Reply: SGS suspension
