Miles per tank
Has anyone with a 2014 Limited determined the maximum miles out of a tank of gas? What I mean is have you rode until all 6 gallons were gone or almost gone and how many miles did you get? I realize setups will vary based on tunes, stock, non-stock, etc. I've ridden well beyond when the digital gauge goes LO RNG. Every time I think I have used all of the fuel, it only takes 5.5 gallons to fill the tank. The most miles I have gotten is 225. My setup is stock header, SE high flow breather, Street Cannons and SE Pro Tuner download.
Im not so sure how accurate the digital fuel gauge is. On a recent 3000 mile trip down through the blueridge parkway, there were times when i would fill up and the miles to empty would vary between 230 and 280. Usually it was closer to the 250. Id always fill the tank completely full, so who knows?
We did get caught once where we forgot to fill up and were on a section of the BRP where it was 30+ miles to the next gas station and the Low Range indicator came on. I thought for sure the thing was going to run out. When we finally got to the gas station, the same thing happened as you, it took 5.5 gallons to fill it.
Not sure id want to push my luck with it again especially with the variance i see in the miles to empty.
Had fun with it in Sturgis this year. Did a couple rides from Rapid City to Sturgis, then rode Vanocker Canyon, Nemo Road back to Rapid City. Pulling out of Sturgis after a refill it would show around 200 miles to low fuel. By the time I got back to Rapid it would show around 230 miles to low fuel. Fun conclusion: riding the Hills puts extra gas in your tank!
![Icon Headbang](https://www.hdforums.com/forum/images/smilies/icon_headbang.gif)
![Icon Dance Tap](https://www.hdforums.com/forum/images/smilies/icon_dance-tap.gif)
![Icon Banana](https://www.hdforums.com/forum/images/smilies/icon_banana.gif)
301.6 divided by 5 gallons is 60 MPG....And that's BS. Even if you burned through all 6 gallons that's still 50 MPG...Which is pretty unbelievable.
52 MPG x 5 gallons = 260 miles...52 MPG x 6 gallons = 312 miles
Can you clarify?
yeah I don't know how people are getting 40+ mpg out of these things I have had 1 96ci and am on my third 103 and I have never seen better than 37mpg. Hell my wife's sportster only does 39-40mpg
added: I was able to put in 5.7 or 8 I forget, but when I parked the bike it started to come out of the overflow tube by the rear tire, it was also more than 90 degrees out, I have a feeling if I just rode away I would have been fine since it was not coming out at the pump.
![](https://cimg1.ibsrv.net/gimg/www.hdforums.com-vbulletin/495x480/img_0460_edited_1_f95a887a496f752f92617ecab6dd096d06f60da1.jpg)
