2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
"No CB module detected" on '14 FLHTK
Old 08-31-2014, 03:24 PM
hunlock's Avatar
hunlock
hunlock is offline
6th Gear
Default "No CB module detected" on '14 FLHTK
I picked up my '14 FLHTK a few weeks ago and had the dealer make my tour pack detachable. In the process, I had a JM in fairing AM/FM/WB antenna installed and simply never put the CB antenna on.
Yesterday I popped off the fairing and put in the JM in fairing CB module and when I went to test the reception and my CB module seems to have vanished.
I did disconnect and reconnect the module as well as the radio itself.
In conjunction, I did also do the 1.18.1 update, but no one else has reported this as an issue.
Has anyone else had this issue? Hopefully it's a simple fix.
Old 08-31-2014, 05:02 PM
rmc115's Avatar
rmc115
rmc115 is offline
If you check before it is fully booted up you will get that message. I know from having to turn on and off the cb with old version software (1.17.1). Wait a couple minutes after riding and recheck. Mike
Old 08-31-2014, 05:07 PM
Hammz's Avatar
Hammz
Hammz is offline
??? WTF? FLHTK already has a CB module; why are you installing a J&M CB module? Didn't even know J&M had a CB module that works with Rushmores?
This one makes no sense to me.
Old 08-31-2014, 05:45 PM
offthewall's Avatar
offthewall
offthewall is offline
I believe he's referring to the J&M internal CB ANTENNA.
Old 08-31-2014, 06:38 PM
Hammz's Avatar
Hammz
Hammz is offline
Well that makes more sense, but why did he unplug the CB module to add an antenna? Sounds like he may need to do a system reset.
Old 08-31-2014, 07:58 PM
hunlock's Avatar
hunlock
hunlock is offline
6th Gear
Correct, the J&M internal CB antenna. I only unplugged it after it failed to appear in the comm section in an attempt to make the radio recognize it.
Where is the reset function? I'll give that a go!
Old 08-31-2014, 08:15 PM
FISHPAW's Avatar
FISHPAW
FISHPAW is offline
4th Gear
I believe you need to go into the settings of the radio to make sure you have communications turned on.
Old 08-31-2014, 09:04 PM
Hammz's Avatar
Hammz
Hammz is offline
Search of HDF will find several references. Not done this myself, but comments indicate it works.
Old 09-14-2014, 12:37 PM
RickLB's Avatar
RickLB
RickLB is offline
Check your fuses
FurryOne
Milwaukee Eight (M8)
15
10-01-2017 10:34 PM
brandss
03-27-2016 09:21 PM
russ33541
19
09-30-2015 06:40 PM
dpigguy
Audio Systems
12-02-2012 08:29 PM
craigcrewcheif
08-06-2011 05:40 PM
Quick Reply: "No CB module detected" on '14 FLHTK
