2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Screamin eagle heavy breather elite
Old 09-10-2014, 08:35 AM
Tcain24's Avatar
Tcain24
Tcain24 is offline
Default Screamin eagle heavy breather elite
I have installed this breather on my '14 street glide as was wondering how does the crankcase vent? The kit come with solid bolts to go in the place of the factory bolts that had the hole through the middle of them for venting.
Old 09-10-2014, 11:06 AM
Puttnutt24's Avatar
Puttnutt24
Puttnutt24 is offline
This is interesting. I just purchased a CVO FLHRSE with this A/C and although I pulled the filter, I have left the A/C unit attached. I will look into this, curious.......
Old 09-10-2014, 12:03 PM
Six7One's Avatar
Six7One
Six7One is offline
According to the images the two long bolts have holes in them. Was that not the case with the one you installed? Was looking at this one too. Now you've piqued my interest.
http://www.harley-davidson.com/store...18-29400173--1
Old 09-10-2014, 01:12 PM
Tcain24's Avatar
Tcain24
Tcain24 is offline
The bolt heads were solid with o-rings around them
Old 09-10-2014, 03:35 PM
Webo's Avatar
Webo
Webo is offline
The bolt heads should be solid but if you look at the picture that was linked above the bolt is hollow and has a hole towards the head end and it should vent thru the bolt and out the hole on the side of the bolt.
Old 09-10-2014, 03:55 PM
Tcain24's Avatar
Tcain24
Tcain24 is offline
I didn't even notice the holes in the shank of the bolts when I installed the breather but even still there is o-rings under the head of the bolts that should seal the crankcase from the breather. Maybe not so. Just curious as to how the crankcase actually vents. I have put about 1600 miles on the bike since installing the breather and the filter is already nasty, so maybe there is some venting going on causing the filter to get dirty so soon. Cleaning it now
Old 09-10-2014, 09:17 PM
xhere's Avatar
xhere
xhere is offline
What Webo said. I have the SE heavy breather and that is how it vents.
Old 11-25-2014, 07:42 PM
Wideglide1414's Avatar
Wideglide1414
Wideglide1414 is offline
Yeppp
Old 11-26-2014, 04:50 PM
J929626's Avatar
J929626
J929626 is offline
Vents through the bolts into the back plate then into the intake. This should not cause the filter to get "nasty" but may cause carbon/oil residue buildup on TB and pistons.
TripleF
12-09-2017 11:38 AM
blackwidow98
04-04-2017 04:58 PM
riteway
10-22-2010 07:47 PM
mjcx
Exhaust System Topics
05-10-2010 12:02 PM
Overcamber
09-29-2008 08:06 AM
Quick Reply: Screamin eagle heavy breather elite
