I just installed custom dynamics led turn signals in the front directionals of my 2014 ultra. The work and look perfect but have one issue. When you out the turn signal on, the turn signal flashes at a normal rate but the turn signal indicator on the dash blinks rapidly. Will this harm anything? Should I go back to bulbs?
I just tried it and it's not working, the front and rear turn signals flash normal but the indicator flashes once or twice normal and then speeds up to a rapid flash. I wonder if they changed something. These led boards were purchased two years ago for the front of my boss hoss.
2014 models are different then the previous years. They will not work
When I turn on the four way flasher, the indicators blink at the normal rate. The indicators only speed up when I actually turn on one of the other turn signals. When I do this, the signals themselves flash normal but the indicators flash faster.
