Install after market exhaust or not?
I bought a new 2014 Street Glide last month. My previous ride was a 1996 Road King, which I bought new. Did some performance upgrades on the RK, exhaust, carb, cam, ignition module etc. This Rushmore Street Glide is way superior to the RK, in stock condition. I am actually enjoying the quiet, listening to tunes, a new experience from the loud one I had for 17 years. The difference in power is a lot. So, the question is, what performance mods to make, if any. I don't want a loud exhaust, mid 90 to 100, 110 DBS. So what header, slip on's gives good sound and performance?
I got a set of ebay of bassani mufflers and de catted my head pipe. I would suggest either a decatted head pipe with factory mufflers first cause it is a lil bit louder then normal but still not bad as far as noise levels go. Then i wanted a slight bit more and found these for under 300 bucks slightly used so i got them. Im happy with the sound and just installed a FuelMoto Microtuner last night made it a bit deeper. Loving the bike and new sounds of it. Big sucker is on its way as i type. For those who worry about the cross talk of the stock pipes being decatted the microtuner doesnt use the O2 sensors anymore so they can actually be taken out. Im not looking for every bit of speed or optimum performance out of it just a good running sounding bike and i got it.
Batman
Batman
I went with Street cannons myself, love the zero drone when cruising, I can hear the tunes clearly going above posted speeds, but snap that throttle and and it make everyone's neck twist. Loud pipes may not save lives, but they tend to get you thru blind intersections, and the I've-gotta-call-my-friends-to-tell-them-I'm-driving morons. Your local HD dealer may have a demo unit you can try before you buy.
-Uberjason
-Uberjason
-Uberjason
-Uberjason
Just get rid of the cat!
This might be enough of a change for you without going further into it.
You'll get rid of the extra heat too.
Any mufflers you put on is a waste anyway unless you get rid of the cat.
I like the clean quiet running also for a touring bike, why beat yourself up?
If you do a stage 1 with loud mufflers you'll be wondering why because all
you get is a couple of horsepower and a bunch of noise.
2014 SGS Fulsac DX pipe and Fulsac Recored Mufflers
Thanks to everyone on this forum that has discussed exhaust systems. Like most of you I have tirelessly scoured for information in order to make a good decision about exhaust / mufflers / tuning / air cleaners / Stage one.
I have recently installed the Fulsac DX header, 2" recored mufflers (which BTW Fulsac did the re-core job and welded the new cores into the Stock cans, absolutely immaculate job, no cutting off the slight slash or add on tips, no heat blueing from the welds, looks like they came from the HD Factory this way). I used Steve's fuel map and the tts tuner. Worked brilliantly and for a person that is NOT a WRENCH by any imagination, this project was seamless and about as simple as one could hope for.
From the first call to the folks at Fulsac through the couple of questions I had after installation, it was truly an awesome customer service experience, and even better performance and exhaust note experience.
The Ceramic coated head pipe makes a huge difference for my wife when we are riding 2 up,I think a combination of the Ceramic coating and the obvious elimination of the CAT. An since we live in Central Florida..well you get the picture.
I would have to say there are some real highlights to this but in short the massive cost savings of the Fullsac DX, Cored Mufflers, TTS tuner with fuel map and the Screaming Eagle Elite Aircleaner kit (On Sale at Ocala HD now) was an easy $1500.00 in total for the whole system installed. Which BTW several dealers tried to sell me a similar system and installation for $3K.
The Fulsac system sounds great, the bike pulls like a freight train and overall I can only Thank Steve and Cammie for their help with my 14 SGS.
