Over charging
Yeah that's almost certainly a bad voltage regulator. Over 16 volts will set the diagnostic code and shutdown your speedo. A new V/R is $160 unless it's under warranty. Easy to replace though.
Had the same problem. (thanks to kenny55)
The voltage regulator has been replaced under warranty. Two days later, the battery had dropped to 5.6 volts.
It looks like the overvoltage has destroyed the battery. Battery replaced under warranty.
That was two weeks ago. So far, the problem seems to be solved.
Defective voltage regulator looks like a known problem.
