1157 housing front turn signal
Hi, i own a 19 fxbb and i've bought the rogue rider industries turn signals before receiving the bike (saw multiple videos where people put those turn signals directly on stock housing). But i have received my bike with 1156 housing. Is it possible to change them for 1157 ones and where can i find those?
I would get the whole assembly including wiring and plugs to switch with your front turn signal set. Might have to get a dealer flash for the running light section to work.
Hmm, yeah you're right, i don't think the wire is already here on my european bike.
I'll check if i can tap the new wire around the support thingy (caddy?) under the gas tank without pulling appart the whole ****ing bike.
I really don't get it why harley makes so much modifications, just for a "regional" turn signal.
Thank you for your input.
I did this for my UK FXBB for the same lights
I ordered the US turn signal housing from HD
The lights will have three wires as opposed to the UK two
Black = ground
Purple = signal
blue = running
If will need to route the new light cable through your bars and into the wiring harness in the neck
the existing signal cables will be going into molex sockets
the top set is for the right and bottom is for the left
the wiring will be
3 = black, 2 = purple, 1 = blue (4 remains empty)
so the only difference there from ours is the blue on pin 1
I hooked mine up. The left was working fine, but the right only had amber. I thought it was my wiring. Turns out that I had just over tightened the light on the socket... wasted lots of time on that. So make sure you check that as a trouble shooting step
If you get any problems, let me know and I’ll post pictures
Black = ground
Purple = signal
blue = running
the wiring will be
If you don't mind, i'll be happy if you can send me 1 or 2 pics on how you put the new wires on the harness.
Already changed my handlbars, pulling the right side again already makes me sweat (so tight with a 90° angle on my tbars), but nothing a bit of grease and patience can't overcome. But i'm less certain about the rewirering (never done that).
Okay so on the left side of the neck, you will have a rubber cover that is hiding the wiring harness. Take this out
I wanted as much room as possible, so I opted to move the tank up to enable full access to the harness space. For this you just need to remove the connection below the tank and the two bolts at either end of the tank that holds it in place. I then just lifted the tank a couple of inches up. You don't need to empty the tank or anything for this
Inside of the harness you will see that it is split in two main sections, up and below.
Both the upside and downside will have a connector that currently holds two cables for UK (black and purple). Remove these from the sockets
You will then need to 'depin' the cable from the molex plug
Here is the best video showing this process
Once you have pulled the new cables through your bars for the US turn signal housing, you should have three cables (black, purple, blue)
You will need to put a pin on each of these for the molex connection
These are HD-72910-11, Terminal, socket 20-22 AWG (5)
But you can get them here instead:
https://www.ebay.co.uk/itm/Harley-Da...72.m2749.l2649
https://www.ebay.co.uk/itm/Harley-72...72.m2749.l2649
Put the pins on the new cables, and push them into the molex connector
Pin 1 = Blue (running)
2 = Purple (signal)
3 = Black (ground)
then just push the plugs back into the two sockets
bottom for for the left
top is for the right
Take your time crimping the pins onto the wires, they are fickle *****
If the lights don't come on correctly (E.G, running light is amber), play around with the LED inserts that go into the signal housing and make sure they are at the right tightness. Do this before double guessing your socket wiring...
2 = Purple (signal)
3 = Black (ground)
adiddik (05-02-2019)
