2018+ Softail Models Breakout
'18 Slim need a better horn
Old 07-14-2019, 01:10 PM
Hulkss's Avatar
Hulkss
Hulkss is online now
Received 1,849 Likes on 976 Posts
Originally Posted by Guglielmo Marconi
Same problem with my ‘18 Slim. How you succeeded to dismantle stock horn? It was a PITA for me this afternoon.
Take out that bolt in the photos and the small torx 25 screw on each side of it and the stock horn will come out. Remove the assembly and put the bracket back without the horn. Then put on the new bigger horn as shown in the photos.
The following 2 users liked this post by Hulkss:
Guglielmo Marconi (07-15-2019), TroutBum (07-17-2019)
Old 07-15-2019, 01:21 AM
Guglielmo Marconi's Avatar
Guglielmo Marconi
Guglielmo Marconi is offline
Understood you’re talking about this bolt (not central one on the back side of the horn)
Thank you, sir. Very helpful forum.
Old 07-15-2019, 09:10 AM
Hulkss's Avatar
Hulkss
That's correct.
Old 07-16-2019, 07:32 AM
Parrothead1809's Avatar
Parrothead1809
Parrothead1809 is offline
I have to agree. The horn on my 19 Deluxe is not going to get any R-E-S-P-E-C-T either. Has anyone attempted to replace with one of the Denalie Sound Bombs (https://denalielectronics.com/collec...oundbomb-horns)? The "mini" (@ 113db) appears to be plug 'n play (but I haven't double checked the voltage, mounting options, etc yet), where the air horns (@ 120db) require a harness but should really get some attention!
Thoughts?
-PH
Old 07-16-2019, 09:03 AM
Guglielmo Marconi
I'll try for HELLA S90 low tone. Reverting with outcome.
Old 07-26-2019, 08:52 PM
cjdyna's Avatar
cjdyna
cjdyna is offline
Anyone try the Arlen ness horn? Looks nice but $200 seems a bit much
Old 08-06-2019, 12:53 AM
Guglielmo Marconi
Settled with stock horn + Hella S90 parallel. Couldn’t manage to upload 6sec video with sound (file exceed forum limit)
TroutBum (05-09-2020)
Old 05-09-2020, 08:39 AM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,704 Likes on 1,989 Posts
Originally Posted by TxSpeedster
I went with a Wolo 270-2T in 360hz, 115db. Its mounted where the OEM horn was. Little bigger and bolder, I like it.
I have the horn pictured, but I'm hesitant to mount it where you did. Notice how the crash bar is "scooped out" for fender clearance. I'm not sure I should mount the horn out ahead of the crash bar like you did. I'd hate like hell to have the horn hit the front fender when the forks bottom out.
To answer your question, yes, I HAVE bottomed the forks. Such is the state of the roads up here.
Old 05-09-2020, 11:08 AM
daniel.sm's Avatar
daniel.sm
daniel.sm is offline
I changed the horn of my LRS with the OEM horn that comes with the touring models (sans the horn side cover).
It was really a garage work of 30 min between disassembling the pancake horn and putting the new one....as explained in another comment with the exact procedure, it's taking one out by removing the bolts, putting the horn bracket in place again and then bolting the new horn
Keithhu
Milwaukee Eight (M8)
15
07-29-2017 08:26 AM
natetp1227
05-18-2010 07:45 PM
workingtoride
06-29-2009 12:29 AM
Anthony8858
06-05-2009 12:06 PM
Quick Reply: '18 Slim need a better horn
