So I just got bike back after getting the s& s 475 cam installed here are the dyno results with bassani road rage,s&s 475 cam and dyno tune didn’t get a dyno from before so cant compare it to anything but what do you guys think
What do you think? Looks like it pulls hart to redline.
That exhaust looks like it works well with the 475 cam.
Looks good great cam! Slight dip in torque which is normal as to what I have seen with that cam. Same horsepower as my stage 3 cam only more torque. Was it PV tuned? Mine is probably hampered some by the limitations of the SE tuner. Looks like they ended the pull a little short of 6k but I bet it actually would have pulled to 6k.
Agreed I would not use the SE tuner or a SE cam except for with a brand new bike to conserve the warranty. Satisfied for now it runs great but after my two years are up I may go back into the motor for upgrades.
Very nice! I keep waffling between the S&S 465 and 475.
Yours doesn't show the pronounced dip that others have right off idle. In fact, looks exactly like the curves Moonshine Harley shows on youtube for the 475. Must be quite a kick coming on the cam between 2000 and 2500 rpm.
Whose tune are you using? Have you tried the auto tune? I hear that the Bassani pipe doesn’t have enough back pressure for the m8 engine. That being said, I have the exact same setup... will be installing my fuel Moto tune tomorrow.
Power vision no I havnt tried the auto tune, I have heard the same with the bassani pipes but I’m happy with my results any how and like the look of the bassani, hope you like the fuel moto tune will you have dyno results after ?
I only have 600 miles on the bike and I went for the full cam chest so would want to break it in first. Currently the bike has a Harley tune for a similar cam.... it runs pretty good but certainly not the way it will. I’ll install the PV today. I also have the HD smart tune with the wide O2 sensors... apparently, fuel Moto took that into consideration when they programmed the PV for my bike.
i was surprised how much louder the bike is with the cam. It now sounds the way a Harley should. I too like the way the Bassani looks.
