2018+ Softail Models Breakout
Koso D2 TPMS
Old Aug 6, 2025 | 10:56 AM
Hdlowriderst's Avatar
Hdlowriderst
1st Gear
Default Koso D2 TPMS
Since the D2 Koso digital gauge supports TPMS does that mean if I add TPMS sensors to the rims I will be able to see tire pressure on the gauge? Or is there more to it than that? If not does anyone have recommendations on how to add TPMS? I’ve seen the cheap Bluetooth ones that you can monitor using your phone but I’m guessing they are not very accurate.
Koso D2
2023 Low Rider ST
Old Aug 6, 2025 | 11:35 AM
Biggzed's Avatar
Biggzed
Probably have to call/email Koso to be sure, but my suspicion is you cannot just add TPMS to the rims and have it all work. I believe the Koso is going to read what the ECM provides. So if the bike isn't already TPMS capable, adding the Koso will not change that.
My Dad uses one of those valve stem TPMS Bluetooth monitors. It's accurate to within a couple of lbs. Not too bad if that's something you wanting to have at your fingertips.
Zach
Old Aug 6, 2025 | 04:51 PM
Hdlowriderst
1st Gear
I just contacted Koso and the the ECU does need to support TPMS so it’s a no go. Bummer. I will try the Bluetooth ones. Thanks.
Old Aug 12, 2025 | 03:01 PM
Blackout25's Avatar
Blackout25
Hey man,
Here's a couple of reviews, if youre an Amazon shopper for those bluetooth sensors.
Currently use this one, Fobo. very happy with them and the app, would definitely recommend. I just flip on bluetooth, open the app and ike 20 secs itll catch a fresh read from them both. Ive taken them off in the winter storage months to save batteries. 2 summers, havent had to change them out yet. In spring soon as they go back on, they update right away. Very handy to just pop it open instead of putting a gauge on the tire before a ride.
Amazon.com: FOBO Bike 2 tire pressure monitoring system (Black) – external monitor, bike tire, temperature sensor, wireless, for smart bike, motorcycle, ebike & bicycle : Sports & Outdoors Amazon.com: FOBO Bike 2 tire pressure monitoring system (Black) – external monitor, bike tire, temperature sensor, wireless, for smart bike, motorcycle, ebike & bicycle : Sports & Outdoors
Amazon.com: leepee Motorcycle Tire Pressure Monitoring System, Tire Pressure and Temperature Alarm, Wireless Motorcycle TPMS with 2 External Sensors, Support iOS and Android : Automotive Amazon.com: leepee Motorcycle Tire Pressure Monitoring System, Tire Pressure and Temperature Alarm, Wireless Motorcycle TPMS with 2 External Sensors, Support iOS and Android : Automotive
Dont use this leepee brand, waste of money. App is horrible, sensors are horrible. Took over an hour to get them connected, and would only update every 20 mins or so. I stuck them on a lawn mower with like 5 psi, took forever for it to recognize it was low.
Old Aug 12, 2025 | 04:44 PM
Ivan45acp's Avatar
Ivan45acp
I'll second the Fobo. They have been quite handy. Just got back from a 3700 mile trip with them on. Super easy pressure check. No issues. I found them to be within 1-2psi of a gauge.
Ozharleyguy
Oct 19, 2024 06:54 AM
Ridin-Slow
Oct 16, 2023 03:52 AM
edilgdaor
Jan 27, 2020 07:22 AM
skypilot_one
Jun 29, 2016 04:01 PM
mmcbeat
Wheels/Tires
Jun 17, 2014 10:59 AM
