Looking to install Air Ride... but questions...
I just finished. Since i don't have ABS, I mounted the compressor in the ABS tray (which I had to cut down so it fit). The manifold was zip tied to the bottom of the ABS tray (as I saw in web searches) The switch was mounted to the hole in the frame behind the rear cylinder. I wired the pressure switch into my accessory circuit. (bought accessory plug-in from HD and cut everything off I didn't need) There wasn't enough slack on the accessory plug for me to splice into the wire I wanted.
