What octane gas should I use?
91-93 any higher is a total waste and may not run right.
Your ride is designed to run on 91 that is governed mostly by compression.
The higher the compression the higher the octane needed. Higher octane burns slower .
If you put to high and octane in, fuel does not ignite when it should to low it can ignite under compress before it should.
