"Bike" amp bench test results (initial batch 6 amps)
the only comment I can make here is, we would theoretically compare "apples and oranges", as I did my tests all exactly the same with the same power resistor bank, set up etc.
now in real life we know the moto is a powerful amp.
specs say 45W RMS at 2 AND 4 ohm. simply not going to cut it and for same price or a little bit more there are way better amps out there.
thanks Slyedog - seems you got your equipment as well.
I completely understand that. If I was to do this more often I could build a resistor bank with some 4 ohm 100 watt resistors. I could do 4 in series parallel to be good for up to 400 watts. The power supply I can get for about $180 for a 50 amp 13.8v but can't justify the expense as I'll likely use it only a few times.
As you might have read I tested all amps on my bikes power, Engine running.
I already ordered them too. I assumed I could run them like I would calculate 4 speakers in series parallel to get my 4 ohm load. Now I realize I would only be good for half the watts. Appreciate the info as I am becoming more interested in electronics again. Even outside of audio.
I gotcha on the parallel thing. The wattage will only be 200 instead of 400 due to the series in the circuit. So if I want a 4 ohm 400 watt load, I need 4 16 ohm 100 watt resistors all in parallel. Or I get 200 watt 8 ohm resistors and have a 400 watt 4 ohm or a 800 watt 2 ohm. Wheels are greased now.
Geary Thomas (03-02-2018)
