"Bike" amp bench test results (initial batch 6 amps)
#42
Fairing is covering all underneath, so same as all other non marine amps...
If you decide to try to off road into rivers, etc ;-) probably not a good idea. otherwise I would not have any concern...
Shuishe (02-05-2020)
#43
Hail Caesar (09-17-2021)
#44
#47
#48
#49
#50
see link below...\
in a nutshell (input voltage was a tad low from my bike compared to other tests):
specs are correct, this is a beast and fits in up to 2013 Batwings.
Class D, so hit and miss FM reception.
SS PN 4.1000D (250W @ 2 ohm; 150W @ 4 ohm)
2 ohm: ~237Watt
4 ohm: ~140Watt
Current street Price: 180USD.
brother/sister of this amp, the PA RZ4.3000D, can be found online for 150 USD.
confirmed to fit in batwing fairing as well (Thanks Haze)
For me, this is the #1 amp I recommend if on a budget and want to run 6 or 8 speakers (keep in mind, when running speakers parallel, make sure you use 4 ohm speakers, like the Pioneer 6x9s, BTs, etc).
SS PN 4.1000D test results
2 ohm: ~237Watt
4 ohm: ~140Watt
