Amp question. 2 ch 4 ch.
Old Aug 29, 2015 | 10:16 AM
  #31
haze324's Avatar
haze324
Originally Posted by Budda109
The high level inputs are tapped into the R-L Front out and R-L Rear out as pictured here?
Bingo! That's it. The "outputs" from the radio to the "inputs" of the amp.
I'm not 100% sure on the colors off the top of my head.
Old Aug 29, 2015 | 11:30 AM
  #32
Budda109's Avatar
Budda109
Default Manual
My buddy has a 2012 Manual. My bike is a 2011. I would think they are the same. I think the XM is the only thing I do not have as a option. once I rip it all apart I should be able to know for sure.
Old Aug 30, 2015 | 03:16 PM
  #33
Budda109's Avatar
Budda109
Now don't let the 6 3/4 scare you off. Same footprint as the 6.5. They sound very good with the PA and more importantly you won't blow them up. Unhook the old speakers and tie off the wires. Use 16 gauge wire and run the speaker wires straight to the speaker side of the amp. To keep it simple use the back channel for the pod speakers and use the front channel for the fairing speakers.[/QUOTE]
Got started now have a family thing. Have power ran from battery. Fuse is out on positive line at the moment. Made room on top of HU to put amp. Ran 14 gauge wire to the rears under tank. Is 16 gauge ok in the front? Also on the kicks. for the rear just used 4 screws provided and screw into pods? Do you know if that's particle board and needs pilot hole, or just self tap the puppy's in the pod? Will do more tomorrow night and finish Tuesday. I hope. Removing the tank was pretty easy and really helped hide and run the wires very nice. Thanks
Old Aug 30, 2015 | 05:45 PM
  #34
Gannicus's Avatar
Gannicus
Got started now have a family thing. Have power ran from battery. Fuse is out on positive line at the moment. Made room on top of HU to put amp. Ran 14 gauge wire to the rears under tank. Is 16 gauge ok in the front? Also on the kicks. for the rear just used 4 screws provided and screw into pods? Do you know if that's particle board and needs pilot hole, or just self tap the puppy's in the pod? Will do more tomorrow night and finish Tuesday. I hope. Removing the tank was pretty easy and really helped hide and run the wires very nice. Thanks[/QUOTE]
I normally drill a pilot hole. Makes it much easier to put the screws in. The self tappers will damage the material on the outside of the pod. Not very much. But I like everything to be clean. Looks like you are on your way to a great sounding system!! If you have any questions or need any help fire away!! Keep us posted!
Old Sep 1, 2015 | 11:02 AM
  #35
Budda109's Avatar
Budda109
Default Installed!
Got it installed last night. Sounds great. May have to redo the gain adjustment. With the gains off they are at 8 oclock. I used a Van Halen CD. And set them at 10 oclock. I had read not to use a MP3 player or Ipod. because the equalizer would fudge the settings. Well my iphone is pretty much all I use. And it distorts at high levels of volume. I may just turn the volume down on the Iphone that may do it. I just took it for a quick ride when I was done and did not think of that at the time. Plus it was after a few Captain and Cokes! Thanks for all the help and suggestions.
Old Sep 1, 2015 | 06:48 PM
  #36
z71_fourwheelin's Avatar
z71_fourwheelin
Do you have the crossover set to AP or HP. Try HP if your on AP
Old Sep 2, 2015 | 07:07 AM
  #37
Budda109's Avatar
Budda109
Default Setting
Mine has 3 settings AP-F-HP. I have it on F=full. I guess I can play with it. My understanding was to set it to full so I would not loose anything since I do not have a sub. Thanks
Old Sep 2, 2015 | 07:34 AM
  #38
AAWAV's Avatar
AAWAV
depending on your speakers, you might want to "cut" out 50Hz and lower. most speakers cannot produce anything below 40-ish any way. wasting power as well as potential damage of speakers (again depending on the speakers used).
Old Sep 2, 2015 | 09:49 AM
  #39
Budda109's Avatar
Budda109
Default settings
So that would set setting it to LP correct?
Old Sep 2, 2015 | 09:58 AM
  #40
Gannicus's Avatar
Gannicus
No Sir. You want HP if you are going to manually set the crossover. Set to HP and turn your dial to 70-80 HZ. The alternative is to run full or flat. This setting lets all your notes pass through. The LP setting is for subs.
