New Focal Flax Coaxial
Here is what I found on Focal sight. Keep in mind this is for the component speaker. Didn't see anything on the coaxial side.
http://www.focal-america.com/product/ps-165-fx/
165F
Nominal power 70W
Maximum power 140W
Sensitivity (2,83V/1m) 91.6dB
Cone Flax Surround Butyl Nom. impedance 4 ohms DC resistance 3 ohms VC diameter 25mm 1" VC height 13mm 5 5/16" Former Kapton Layers 2 Wire copper Inductance Xmax 4mm 03/16" Magnet d x h 85x30mm 31/3"x 13/16" Magnet weight 900g 1.98lb Flux density Gap height 5mm 03/16" Net weight 1050g 37.06lb PARAMETERS Fs 70Hz Vas 8.5 l Qts 0.68 Qes 0.72 Qms 12.5 Re 3.2 ohms Sd 132.7cm2 Cas 6.07e-08m5/n Mas 85.94 kg/m4 Ras 3010 ohms.ac Cms 350µm/n Mms 15.4g Rms 0.5kg/s Ces 521.93mF Les 9.99mH Res 54.69 ohms BI 5.4n/a SPL 87.8 dB/W/m
165FX
Nominal power 80W
Maximum power 160W
Sensitivity (2,83V/1m) 91,3dB
Cone Flax Surround Butyl Nom. impedance 4 ohms DC resistance 3 ohms VC diameter 32mm 11/4" VC height 15mm Former Kapton Layers 2 Wire alu Inductance Xmax 5mm 03/16" Magnet d x h 90mm x 17mm 39/16 x 02/3" Magnet weight 400g 0.88 lb Flux density Gap height 5mm 03/16" Net weight 1350g 2.98 lb PARAMETERS Fs 74Hz Vas 7.4 l Qts 0.85 Qes 0.92 Qms 10.9 Re 3.2 ohms Sd 124.7cm2 Cas 5.3e-08.5m5/n Mas 76,28 kg/m4 Ras 3222,63 ohms.ac Cms 390µm/n Mms 11.9g Rms 0.3kg/s Ces 711.43mF Les 7.27mH Res 33.27 ohms BI 4.44n/a SPL 87.6 dB/W/m
c_mancuyas8
06-16-2017 06:03 AM
knightenforcer
02-11-2016 10:22 AM
DRAGO'S BIKE WORKS
Vendor For Sale Classifieds
03-19-2010 07:36 AM
