Mark this thread as Unsold
FS: arc audio bx125.2 mini and ppi micro 520.4
Both work excellent have had no issues. There are scratches from being in the bags but nothing that affects function.
Offers welcomed. PayPal only
The ppi is only 3 months old.
PRICES INCLUDE SHIPPING
ARC AUDIO $200
PPI $80
ARC AUDIO SPECS:
2 Channels @ 4 ohms 70 Watts
2 Channels @ 2 ohms 125 Watts
1 Channel @ 4 ohms (bridged) 250 Watts
Frequency Response 20Hz - 20kHz
Crossover Range 50Hz - 550Hz Variable
Bass Boost No
BX2 Technology Yes
S/N Ratio 101 dB
Input Sensitivity (Low) 170mV - 3.5V
Fuse 1 x 30 Amp
Dimensions 8.25"(L) x 4.8"(W) x 1.7"(H)
PPI SPECS:
iON Series 4-Channel Class D Car Amplifier
RMS Power Rating:
4 ohms: 100 watts x 4 chan.
2 ohms: 130 watts x 4 chan.
Bridged, 4 ohms: 260 watts x 2 chan.
Pulse Width Modulated MOSFET power supply
Low-Heat producing circuit
LED power (green) and protect (red) indicators
Balanced signal input
Double sided FR-4 PC board
Variable Bass Boost (0 to +12 dB bass boost at 45 Hz)
SMT (Surface Mount Technology) for easy installation
Soft start turn-on
2 or Mono channel operation
Speaker-level (high-level) inputs with signal sensing for automatic turn-on
3-way protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heat-sink
Input sensitivity:
Level: 200mV-6V
Fixed high-pass filter (80 Hz)
Fixed low-pass filter (80 Hz)
Dimensions: 5-5/16"W x 9"L x 1-11/16"H
ARC AUDIO $200
PPI $80
ARC AUDIO SPECS:
Bass Boost No
BX2 Technology Yes
S/N Ratio 101 dB
Fuse 1 x 30 Amp
PPI SPECS:
RMS Power Rating:
Soft start turn-on
Input sensitivity:
Level: 200mV-6V
DRAGO'S BIKE WORKS
Vendor For Sale Classifieds
03-19-2010 07:36 AM
