Mark this thread as Unsold
FS: 5 channel micro amplifier
- Class-D Digital Full Range 2-ohm Stable Stereo
- Tri-Mode Capable
- Output Power:
- 4 Ohm RMS: 66W x 4-ch + 210W
- 2 Ohm RMS: 85W x 4-ch + 330W
- Bridged: 151W x 4-ch
- Max power: 900W
- Full MOSFET DC-DC PWM Power Supply
- Frequency range:
- 10Hz-20Khz (1,2,3,4ch) at 4-ohm
- 10Hz-250Hz (5ch) at 2-ohm
- Speaker impedance: 2,4,8 Ohm
- Filter Frequency:
- Low pass: 35-250Hz (5-ch), 12dB Oct.
- High pass: 35-250Hz (1,2,3,4), 12dB Oct
- Bass boost: 0-12dB at 45Hz (5ch)
- 4-way Protection
- Chanel separation: 55dB
- Double Sided FR-4 PC Board
- SMD Technology
- High level input connector(Auto Turn On)
- Remote Bass Control
- Variable Low Pass Remote Dashes Mount Gain Control
- Adjustable Gain Control
- Dimension: 4.72” (W) x 10.23: (L) x 1.57”
I had this mounted in my Street glide fairing I hit 108db with the set-up I had at the time text is fastest 9315819394
PayPal c_mancuyas8@yahoo.com
If by that you mean plugs directly into stock hd harness no. It does have high level inputs though so it can be easily wired to that harness if you're using a stock head unit. At least in my experience
c_mancuyas8
06-16-2017 06:03 AM
PhatAnthony
Vendor For Sale Classifieds
02-21-2013 05:58 PM
DRAGO'S BIKE WORKS
03-19-2010 07:36 AM
