AVC (auto volume control) & Blown Speakers
I am putting this subject back out there as I have been seeing ALOT of members with blown speakers. I myself was once was in the shoes as some of you are in with blowing speakers.
After doing my upgrade on my Rushmore I ran into the same problems of blowing speakers mainly just the tweeters. I had done all my homework figuring out voltages for the output side of the amp as per the Sticky in the forum.
The AVC on these Rushmore's have a very aggressive voltage increase when in use. The figures I used were just for testing purposes. So keep in mind that when doing your settings on you new upgraded system to make sure that you turn OFF the AVC and leave it off
Output Voltages on amp were for testing only
Using 1k hz test tone
At 60mph AVC OFF
14.2 volts battery
11 Volts output at amp
AVC 1 BAR
16 volts amp output
AVC 2 BARS
24 volts amp output
AVC 3 BARS
27 volts amp output
AVC 4 BARS
27 volts amp output
The AVC DOES INCREASE the output voltage considerably !!!!!!
Here is a link from when I had my problems.
https://www.hdforums.com/forum/audio...-speakers.html
At 60mph AVC OFF
14.2 volts battery
AVC 1 BAR
16 volts amp output
AVC 2 BARS
24 volts amp output
AVC 3 BARS
27 volts amp output
AVC 4 BARS
27 volts amp output
09FLHXrLVNV (04-18-2016)
At 60mph AVC OFF
14.2 volts battery
AVC 1 BAR
16 volts amp output
AVC 2 BARS
24 volts amp output
AVC 3 BARS
27 volts amp output
AVC 4 BARS
27 volts amp output
At 60mph AVC OFF
14.2 volts battery
AVC 1 BAR
16 volts amp output
AVC 2 BARS
24 volts amp output
AVC 3 BARS
27 volts amp output
AVC 4 BARS
27 volts amp output
One way to tell for sure is to increase amp gains by 1.8vac and check for distortion. Should be easy on a amp with adjustable gains a DMM and the DD-1.
The BT hand control modual have AVC or Mute as an option. I have one that does both on the SG, but have the AVC off and use Mute.
