kappa's and diamond micro4v2
I am wanting to upgrade my amp and speakers on my 2015 ultra limited. I am new to this forum and have been reading lots of info on amp and speaker choice. I just want to be sure I am going like what I purchase.
I am thinking about the infinity kappa 62.11 speakers with the diamond micro4v2 amp.
Will this be a good combination in my ultra?
Will I loose fm reception with this amp?
Where is the best place to buy this amp and speakers?
My other thought is same speakers with 2 pbr300x2.
Which would be the best combo?
Thank you for your help.
The newer bikes have a very good track record in regard to losing FM with the class D amps. Pretty confident you will maintain your FM with this combo and yes the micro 4 with the infinity kappas is a great combo for your scoot. If you can afford to upgrade the speakers. Go with the Focal KRC's in the fairing. Contact forum member LL247 for pricing.
I have looked for the B54. I keep getting that it was discontinued. Money was part of the reason I was looking at mounting 2 pbr300 amps. But it looks like it would not save me much. I don't have a problem wiring what I need to I am going to build the harnesses I need for the speakers and amp. They are expensive if you buy them already made.
Kenbow (11-18-2017)
I do not know of a reliable flash that works. That's not to say there isn't one, out there but I haven't seen one. The most successful method I know of getting the best sound out of the stock HD Rushmore radio is to use the BT Line Levelers, stock flash, and software version 1.19.0.
Here's a pic of the BT breakout harness.
