Help me build my 16 SGS
Picking up a 2016 Street Glide Special tomorrow morning. I got a stellar deal on it used from a guy that needed to get out from under it due to financial issues. I paid what he owed, which was way lower than KBB or even dealer trade. The thing is immaculate and perfect in every way. EXCEPT for the boom audio installed. So help me build a system....I have been looking and reading and kind of settled on the Polk mm651 and a RF 300X2 amp....however is there something else in that range I would be better off buying? I also looked at sound stream, any reason to go SS over RF? What are the chances I'll lose FM stations with the D-Class amp? Do I need a marine version of a speaker? My understanding is the mm651um has non removable grills and won't work for my application.
Ok, you are in a good place here by asking questions before buying. Now for a couple questions for you.
Fairing only set up, do you plan to add on later (lids/lowers/tourpak)?
Do you want loud and clear at 80+mph or warmer and loud on the back roads?
What is your budget?
And congrats on picking up that good lookin scoot.
Beautiful sled brotha!!!
$500 is gonna be damn tight!!! Hold off a bit and do it right the first time.
U can start gathering parts for the install like the BT355, but shop the amp and speaks a bit and save up to get the right.
If it's going to remain a 2 speak setup, it would not hurt to grab a JL MHX 280/4 amp before they are sold out.
T.
T.
Originally Posted by Bike medic
And yes it'll remain 2 speaker I'm pretty sure. I don't want anything crazy. Just a good all around set up. I keep seeing people do Polk audio and the Rockford amp. Is that not a great as a set up as theyre claiming?
The DD AW6.5 are the best full range speak going. Most of us addicts on here have tried everything from Polk to the $1k speaks and those DDs just seem to bring it. Crisp, clear, and warm as well. If ur strict on budget the DD CC6.5 are the little sister and do damn good as well. Components so ur gonna have to invest a couple more minutes into the install but components smoke coax.
Patience is the key.
T
