Arc PSM - LOC or no?
Old 05-10-2017, 09:00 AM
Adenton528's Avatar
Adenton528
Adenton528 is offline
Default Arc PSM - LOC or no?
I got what I hope is a great deal from a local dealer on the PSM
My question for the group that's using it is, is there benefit to using a LOC and if so, what brand or model is recommended?
Thanks in advance.
Andy
Old 05-10-2017, 09:01 AM
BaggerAudioLab's Avatar
BaggerAudioLab
BaggerAudioLab is offline
Thanks in advance.
Andy
use a LOC.
Adenton528 (05-10-2017)
Old 05-10-2017, 10:44 AM
matt76cmich's Avatar
matt76cmich
matt76cmich is offline
Going from high level input (stock speaker wire to PSM) to a LOC off the stock speaker wire (to the PSM), definitely use a LOC. It seemed to make things a little more clear sounding.
Old 05-10-2017, 11:17 AM
Springerfan's Avatar
Springerfan
Springerfan is offline
Is there anything better than the PAC SNI-35 or is it good enough?
Old 05-10-2017, 12:49 PM
SgtMic's Avatar
SgtMic
SgtMic is offline
Do you use 1 to feed the PSM or use2?
Do you make any adjustments to the loc or leave the factory settings?
Old 05-10-2017, 12:57 PM
cpbedor's Avatar
cpbedor
cpbedor is offline
I started with 2 so I could have "fade control" and realized how ridiculous that was so I deleted the huge breakout harness and one SNI-35 so now I am running one LOC and the DSP is set for 2 in 6 out. Sounds identical to having two LOCs. No regrets.
Old 05-10-2017, 01:52 PM
SgtMic's Avatar
SgtMic
SgtMic is offline
I already have a pac, so I'm good there.
Old 05-10-2017, 08:09 PM
matt76cmich
1 SNI-35. 2 in 6 out for me as well.
Old 05-10-2017, 08:27 PM
Springerfan
I would like to keep the fade control so I ordered 2 . I found the PAC SNI-35 on Amazon for $8 each shipped. I hope to get them on Friday so I can start tinkering with the PSM.
Old 05-10-2017, 09:30 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,235 Likes on 999 Posts
Wouldn't the PAC SNI-15 do the same thing? Is there a need for the adjustable LOC?
Quick Reply: Arc PSM - LOC or no?
