Polk MM652 Rushmore TP Install
Wanted to share my thoughts and a couple of pics of my Polk MM652 install into my Rushmore TP pods.
First, I was trying to avoid using spacers if I could help it but no go there. I will tell you that they almost fit in the pods if you turn them so the writing is upside down.
Second, I used the plastic adapters that come with the Polks as spacers since they are about 3/16" of an inch thick. I just dremmelled the tabs off of the outside.
Third i I decided to use the Boom! Stage I grills. I used some double backed tape and some black vinyl around my "homemade" spacers so they would look better with the grills.
