How to go louder with tweeter pods?
all the hoodoo is impedance matching so the system is balanced. if you drive a 2 ohm speaker with a 4 ohm amp, you will over drive the output amp which will cause distortion and heating and possible failure.
now if you go the other way, drive 2 ohm amp into a 4 ohm speaker, you will not over drive the output but your high frequency response will be lowered.
So aside from the Focal tweeter anyone else have good luck placing a tweeter in these tweeter pods?
If your only concern is the hole's that are already drilled in the fairing for the pod. Harley makes a real nice dummy pod to replace the Hog tune pod. If it were me I'd still go with the Pro Audio set up in the fairing, B3 horns in the gauge holes and PRV neo's in the fairing. Doesn't get any better than that if your goal is loud and clear.
Originally Posted by truejdm
This is why I'm here. Looking at different options.
Also, where do you buy the B3s?
Pricing everything. Those prv speakers for a hundred bucks. Was surprised how not expensive they are.
That makes more sense. Why would the PA's not be a good 2 speaker setup? I do plan to add the lids. Just hate the idea of color matching the Merlot Sunglo. (i've got close, not exact). Looking for some amp recommendations.
