What amp fuse are you guys running on the Focal FDP sport amp ? Im trying to get some parts ordered so they will arrive around the same time as the amp. Also what size is the power wire that comes with the amp ?
most told me 50 or 60, I didn't use one at all, I figured if they required one they would have either included it, or said in the directions to use one? but now I'm thinking I need to add one....
Jacob at Focal said it is definitely needed. The 2 internal fuses are 25 each so he didn't give a specific number but said more than 50. I went with 60. There's another thread on it somewhere.
I went with a 60 amp circuit breaker. I figured it would be easier to reset it than carrying around another fuse if it should blow (such a bad thought).
I bought 2 extra fuses with mines, figured ill loose one and tape the other around the fuse holder.
