Audio upgrade install help and recommendations
Yes I agree man. That thing is STOUT! Little pricey compared to others but I really like that it isn't just a flat plate that sits on top of the HU and it uses all the bolts from the stock plate. I.E. the back and side bolts. Seems like a perfect tray for a larger and slightly heaver amp.
Gannicus, what's the difference between the DB652's and the MM652's? They are both rated at the same RMS and Max wattage and I see that the MM's are $100 more a set and the DB's are rated at 40Hz → 22kHz and the MM's are rated at 35Hz → 40kHz but I don't know what that means.
Just for $h1ts and giggles, if I was to get a 3rd set of speakers to the lower fairing's, would the amp be able to power them? The amp is rated at 140 watts RMS per channel by 4 channels.
Ok well i'm down to 2 different speakers. The Kappa 62.11i and the Polk MM652. Wonder which is better? The Kappa's are rated at 75 watts and the Polk's are rated at 100 watts RMS. Price is $99 for the Kappa's and the Polk's are $150 a set.
When I stated that I wanted to add speakers in my lowers that amp was recommended to me by several folks and I am glad I got it. I left the system running a couple of times while doing other things with the fairing cap off and the amp did not even get slightly warm to the touch.
Another thing I can say is I decided early on not to go TOO cheap on the speakers. I've never paid as much for a set of speakers as I did for those ADs but I'm glad I did. The company has excellent service too. I am also well pleased with the Motos in the fairing as well.
If you are referring to the PN4.1000d I am running four AD Designs Cx621s on the rear channel and two WDX6 Motos in the fairing and it can get louder than I want it to.
I just realized the kappa's are 2 ohms...
That's why I started this post. I'm looking for everyone's 2 cents. I mainly ride at highway speeds so them having a better "presence" appeals to me. I have to admit the Kappa's are looking better and better. Was just wondering about the them being 2 ohms. All the other speakers are 4 ohms. Also, this amp is rated at 250 watts RMS by 4 channels at 2 ohms.
I'm thinking of going with Kappa's in the fairing and then Polk's in the lowers and rear speaker pods.
Infinity has a new Kappa 6.5...the 62ix $130 on amazon..every Kappa has got better! The Soundstream 1000 D puts out 250 rms at 2ohms..stay on the low side with the gains if that's the path you choose! Kappas in the front ....Polks in the back should rock with that amp!
