Speaker lids worth the effort?
I ran DD VO 6X9 in my lids and could here them 2 up at 80 mph with out a problem and provided a good fill with the rest of my system.
Maybe you had your 6x9 underpowered??
You could hear the low bass at 80? I can hear the mids and highs but the lows are gone at 80 and I don't know anyone that can hear the lows at that speed from 6x9's in the lids. Then again, I'm old and cant hear like I use too.
You set your system up for pimping in a lot of touring for miles on end.
Everything is different on your set up so it all comes back to can someone use the same DSP file as the next I would say NO because I set my system up for all out road play at 80 mph and you set up your system for parking lot pimping so no 2 systems will be set up the same.
It all falls back to the same thing about being subjective and were you apply your sound stage. If you are using a DSP or using the crossovers on the amp in play
