Another gain setting question? voltage
Old Sep 27, 2018 | 07:07 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
OP also consider is he going to use the preamp outputs which are rated at 2V or speaker level? That may make a difference in your gain settings and headroom.
The preamps would produce cleaner sound but at 2V you may have to increase the gain setting a little. Maybe someone with more experience can advise.
The problem I see with setting gains with DC voltage readings is the meter isn't going to show clipping. Only an oscilloscope of some kind will show that.
As far as getting a voltage to shoot for with the info Bates has provided that amp was tested at 91 watts with a 4 ohm load. Using ohms law if you multiply watts times ohms and take the square root of that you can find the voltage. So if we multiply 91 times 4 that gives us 364. The square root of that is 19.07, so lets say 19 volts.
So does that make sense or does experience with that equipment say otherwise?
Old Sep 27, 2018 | 11:09 AM
Biggzed's Avatar
Biggzed
I'm curious why the OP used 200w in his original calc when the amp was only rated on paper to produce 160w. Seems like that was a recipe for disaster. I think the values used below are much more accurate (and safe from damage).
Zach
Budda109
Audio Systems
Feb 24, 2019 04:24 PM
wils5150
Audio Systems
Mar 19, 2016 01:28 PM
roussfam
Audio Systems
Sep 17, 2015 06:33 PM
Jason58104
Audio Systems
Aug 2, 2014 10:38 AM
HD32
Audio Systems
Apr 10, 2014 05:13 PM
