New DB Drive WDX6MOTO-G2 and G5
#101
I wasn't sure, I had just read on various other posts how people were saying the speakers didn't even open up until you pumped a lot of juice into them. Did you put any packing in your pods? Thanks for the info I am going to try the port and see how it sounds, as well as the amp changes.
#102
Originally Posted by Rescueninja
No particular reason. I suppose because that's what the speaker can handle, so why not. Going to try it unbridged tonight so I'll see how it sounds. It will be better to get the stereo back instead of the mono from bridging them anyways. Again does anyone have any input about porting the pods?
T
#103
#104
I had it set to HPF, bridged, and have the BT355 with the settings from them. I don't have the gains up very high and just kinda messed with the sensitivity and bass EQ. I don't have any experience with tuning an amp so I am just going off what I've been reading.
#105
I cut small pieces of soundskin and lined the inside of pods, drilled a 1/4" port near bottom of each pod. 80-100 watts is a lot of watts if properly tuned, unless you're trying to get every ounce of sound out of your speakers for a couple of competitions before you put new ones in you don't need to max them out.
#106
#108
#109
I took the bike out after I buttoned it up and the sound is WAY too bright. I can hardly hear the vocal and it just hurts my ears. I am at a loss of what to do. I found one review of the amp after I had bought it on here and they said it was too bright. I'm wondering if there is any adjustment I can make to the BT355 line leveler. Here is a picture from the manual of the amp. Disregard the wiring I am only running 2 channels.
#110
I set the crossover to full, neither HP or LP. Seems it is at full the freq **** does nothing. I don't have the gain up very high.
T
