Beyma 6cx200nd's a bust?
Old 02-20-2019, 12:15 PM
IndyNick's Avatar
IndyNick
IndyNick is offline
Default Beyma 6cx200nd's a bust?
So I just wanted to reach out and maybe get an opinion if I could. I just dropped a set of the Beyma coax's in a 2018 Street Glide. They dropped right into the factory fairing speaker enclosures, I just had to turn them slightly and drill new holes. I used a a Rockford DSR1 dsp with the Stinger spx700x4 amp. I'm running the mids bridged and horns bridged because of the 8ohm coils to create 2 4 ohm channels on the amp. DSR1 is running mids 100-2500hz and horns 2500 and up. What i'm running into is they're just flat as all hell. Literally no mid bass what so ever. Even with a solid week break in they just sound flat. LOUD as hell but thats it. Ive spoken with one of the engineers at Beyma at length about it as well. We even poured sand into the factory pods to get a volume of the pods to try and come up with a port design but to no avail. He said on his end he would need twice the airspace in those pods for ported or unported to make them sound decent. He suggested running the Beyma Pro's with the pods cut open. Just curious what others experience with them was. Trying to salvage this install before I return these speakers.
NIck
Old 02-20-2019, 12:46 PM
Juice's Avatar
Juice
Juice is offline
NIck
Try these
Old 02-20-2019, 12:51 PM
IndyNick's Avatar
IndyNick
IndyNick is offline
Is that the BIke Tronics bracket? I had mentioned that to Beyma's engineer and he said running wide open air space you would still want to use the Beyma Pro version of those coax's. What do they sound like on there? Thanks
NIck
Old 02-20-2019, 12:54 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
NIck
I'm running the 6P200 and they pound. Crossed at about 85 at 12/24 on the slope.
Pretty shocked that those aren't performing well. Sumfin ain't right!
What ur basic tune look like? Slopes? They are damn good quality so over tuning is no bueno.
T
Old 02-20-2019, 01:02 PM
IndyNick's Avatar
IndyNick
IndyNick is offline
T,
Are you running the Neo or Ferite version? In the stock pods or wide open ? Thanks
NIck
Old 02-20-2019, 01:04 PM
Juice's Avatar
Juice
Juice is offline
NIck
Yes they are the BT brackets, you have to open up the inside diameter a little and mount them from the front.
I have not hooked them up, But alot of the big shops are running them with the back of the pods completely open. That many people cant be wrong. I would cut the back of the pod out or go with the BT brackets. They will not be completely open once you button the fairing together. These speakers are rated to play lower than the 100hz you have them set at. How low you want to go may depend on the amount of power you feed them.
Juice
Old 02-20-2019, 01:11 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
T,
NIck
Neo. If u want the 4 ohm version they are the 6Q200ND. Not easy to find though. A little narrower on the freq band too.
There are others that scream and hit pretty damn hard like the 6G but I'm a big fan of the mid bass in the fairing vs the mid range.
Try crossing ur current woof speakers at 85 and ramp that slope up a bit. 24 on the HP and target 0db at 85 and 12 on the LP rolling off at 3k.
The horns are prob good at 2500 and 12.
Just a wild **** guess. I'm running 4 CX300ND and them bitches are far from flat. Good air in the TP and prob .5 cu ft in the bags.
T
Old 02-20-2019, 02:17 PM
IndyNick's Avatar
IndyNick
IndyNick is offline
T,
Those are the 8" correct? You're running those in the Tour Pack?
Old 02-20-2019, 04:48 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
T,
Voodoo Tour Pack.
I really cannot believe ur having a prob with these. Lots of dudes claiming this is the best coax of all time.
T
Old 02-20-2019, 05:03 PM
Dsm Limited's Avatar
Dsm Limited
Dsm Limited is online now
Moderator
Received 8,166 Likes on 2,938 Posts
Alright, do I need to reconsider my game plan? Or do I just need to take the necessary time to tune em, when i do them?
Quick Reply: Beyma 6cx200nd's a bust?
