DB Drive EUPHORIA EX6NCD
Who wants to give these bad boys a try?
• Power Handling : 400 Watts
• Dynamic Wattage : 800 Watts
• Frequency Response : 80Hz - 20KHz
• Sensitivity (1w/1m) : 105.7dB
• Impedance : 5.2 Ω
• Mounting Depth : 3.41” / 88.64mm
• Cutout Diameter : 5.75” / 146mm
• 2.0" (51mm) Midrange Voice Coil
• Neodymium Ring Magnet Assembly
• Rear Mounted Full Sized Compression Driver
• IP52 Rated Paper Cone With Treated Cloth Surround
• Die-Cast Aluminum Basket With Radial Venting
• 1.4" (36MM) Polyester Tweeter Diaphragm
• Wide Dispersion Conical HF Waveguide
• 12dB Passive Crossover Included
• Protective Grills Included
• Impedance : 5.2 Ω
I had to get a set to try, especially after I heard a review claiming they sound better than the Beyma coax. I haven't tried them yet but thought I'd put some pictures up for anyone's curiosity.
WIth an efficiency of 105, and an RMS of 400W they should scream with no DSP required.
c_mancuyas8 (01-01-2020)
