new system
Old Jun 9, 2019 | 09:07 PM
myfun's Avatar
myfun
Default new system
I have been watching and trying to keep up but the time has come to get serious. I am looking for advice on the best options for a under $1000. I want to do a amp, fairing, lowers and tour pack speakers. Im thinking about using the biketronics wiring harness and line levelers but any info on speakers and amps as well as how you mounted in the fairing would be greatly appreciated. The bike is a 2016 ultra
Old Jun 10, 2019 | 08:36 AM
eggwhite93's Avatar
eggwhite93
Are you expecting to get an amp, 6 speakers, line levelers/breakout harness, lower pods, and wiring all for $1000? If so that is not going to happen. You could get 4 speaker in your stock locations for that for sure though.
Old Jun 13, 2019 | 12:45 PM
Juice's Avatar
Juice
Break out harness 260
MMat 601cx 2 sets 240
b52 2 amps 260
amp install kit 60
Juice
Old Jun 13, 2019 | 10:26 PM
myfun's Avatar
myfun
i should have been more specific i already have a few parts that i need im looking for the best amp and 6 speaker options for under 1000
Old Jun 14, 2019 | 04:58 AM
Tailwind's Avatar
Tailwind
Do you have the BT355s + Breakout harness or are you gonna use a different build strategy?
T
Old Jun 17, 2019 | 04:23 PM
myfun's Avatar
myfun
@Tailwind i dont have them yet i've been planning on the bt355 line levelers and breakout harness but i am always open to new suggestions
Old Jun 17, 2019 | 09:39 PM
Tailwind's Avatar
Tailwind
I would plan on using the BT Line Levelers unless u have a local shop is VERY knowledgeable about HD flashes and has a machine to get creative OR ur gonna move towards a pretty complex setup and might prefer a DSP for EQ purposes. OR an aftermarket HU. Note, I have an aftermarket HU and really not doing back flips regarding the broader functionality other than a solid audio signal & google maps.
T
Old Jun 17, 2019 | 10:03 PM
cpbedor's Avatar
cpbedor
Breakout harness is a bulky and expensive piece of wiring that is not needed in any application. Save the money and the valuable real estate in your fairing.
Edit:
And if you're dead set on putting one in, I'll ship you the one I bought then took out of mine
Old Jun 18, 2019 | 07:06 AM
Tailwind's Avatar
Tailwind
Edit:
Totally agree. But I do think the most desirable trait of the Breakout is the plug and play ability to utilize the OEM speaker wiring. If u don't mind the cutting of oem wires or running new wires to the bags or TP then just get the BT Line Leveler.
T
Old Jun 19, 2019 | 06:06 AM
myfun's Avatar
myfun
@cpbedor Im not totally dead set on having to use the breakout harness i do like the plug and play part. Then again any money i can save in the wiring section is more i can spend o speakers and amp
