bt355 VS flash
Old Dec 29, 2019 | 06:30 PM
big papa AZ's Avatar
big papa AZ
Default bt355 VS flash
There's a place around the corner that flashes bikes for RF systems they install. If you had easy access to a flash, would you do the flash over BT355? This would be for a amp and 2 speaker system.
Old Dec 29, 2019 | 07:34 PM
Dsm Limited's Avatar
Dsm Limited
The BT355 makes it easy to plug into your speaker connectors and convert to rca for low level amp inputs.
If your amp has high level inputs you can purchase the connectors and make up plug n play adaptors or tap into those speaker wires and wire direct.
Old Dec 30, 2019 | 10:07 AM
mikes300's Avatar
mikes300
I'm gonna say get it flashed, you can used then use adapters from American hard bag to get your inputs to the amp.
https://www.americanhardbag.com/coll...ket-amplifiers
Old Dec 30, 2019 | 10:19 AM
Tailwind's Avatar
Tailwind
Good info. But as a low cost option what about just using the speaker wire downstream of the harness and hooking up a PAC SNI LOC with RCAs. And if u get a smoking deal on a Stinker amp wiring kit those harnesses are included in their orange box bundle.
Lots of options!!! BT 355, 8/2 flash, AHB adapters, PAC LOC etc......
T
Old Dec 30, 2019 | 10:35 AM
InthewindMN's Avatar
InthewindMN
I just cut a 1.5’ rca cable in half and soldered it onto the ends of the speaker pigtails that go into the pods. Then plugged those into the dsp. You could go straight into most amps (with proper flash) I would think, except SD. The hu only puts out 3-5v anyways, depending on flash.
Old Dec 30, 2019 | 11:00 AM
mikes300's Avatar
mikes300
T
plenty of options for sure.
Old Dec 30, 2019 | 02:58 PM
haze324's Avatar
haze324
I've seen some guys use this one
https://www.sonicelectronix.com/item...SAAEgLhRfD_BwE
Old Dec 31, 2019 | 03:03 PM
big papa AZ
Just found out the shop charges $100 for flash. Seems high?
Old Dec 31, 2019 | 03:06 PM
marshallb's Avatar
marshallb
I would keep looking. $40-$60 seems more reasonable.
Old Dec 31, 2019 | 03:16 PM
Tailwind's Avatar
Tailwind
And this is why the proven BT355 is a popular path.
T
