Dsp
Old May 21, 2023 | 05:12 PM
prostreet124's Avatar
prostreet124
Default Dsp
What's the best DPS for running a SD1200.4, just 4 speaker system for now, would also like to be able to access from phone.
Old May 22, 2023 | 06:21 AM
dynamic098's Avatar
dynamic098
I purchased a Rockford DSR1 from American Hard Bag.
Great support, loaner tool to flash your bike with a credit when you return it.
As far as support, I had a 21 RG Limited that it was installed on, I went to a 2019 Tri-Glide. I re flashed the DSR1 to the 2019 and it would not power up the amp. I called in and they even helped me get that squared away. Love the support from them, very personable!
Old May 22, 2023 | 09:49 AM
cshocker's Avatar
cshocker
The best DSP is one that is tuned correctly.
Old May 22, 2023 | 03:36 PM
fastsoup's Avatar
fastsoup
^^^ - THIS!
OP - what 4 speakers & amp are you running?
Old May 22, 2023 | 03:51 PM
prostreet124
2018 RG, 2 yellow baskets in fairing, 2 PRV's in lower fairings, stock head unit
SD 1200.4
Old May 22, 2023 | 03:58 PM
fastsoup's Avatar
fastsoup
Nice! I have the same set up up front with the CF PRV's - Polk mm 6.5 in the tourpak. Not running a DSP...but have a Kenwood deck which I have used to tweek the EQ...happy with it (for the moment)
Old May 23, 2023 | 08:24 AM
cshocker's Avatar
cshocker
SD 1200.4
I would say a HKI mini then. Let me know if you want to buy one local.
Old May 23, 2023 | 12:05 PM
prostreet124
Message sent
f250inmn
Audio Systems
20
Oct 30, 2018 06:31 PM
kyldh
Audio Systems
13
Jul 26, 2013 08:06 AM
graham steel
Sep 24, 2011 02:57 AM
strtarrow
Jul 27, 2010 05:08 PM
