Soundstream and Polk db651's
Several weeks ago, I added the Soundstream amp and Polk db651's. Just now I was looking at another thread, and it mentioned the db651's are 4 ohm, and the mm651's are 2 ohm. UltraNutz did the install for me, along with the Sony 310. I'm a audio noob, but I believe the amp is bridged. At any rate, it sounded great, but the next day I popped the right one (fairing mounted only). I turned the gain down a bit and put in a right db651. Sounded good with the accessory switch on, but when it's fired up I hear ignition noise on that one side. Last week I popped the left side, and replaced that one too. In addition, I lost all radio reception. I can stream my phone, but it's a drag to not be able to use the radio. Should I be running 2 ohm speakers? Anyone else have the reception issues with the Soundstream amp? Kinda at a loss on what to do next....
dang man.. listening to that Patsy Cline a little too loud? LOL
seriously though.. When you turned your gain down did you maybe loosen the right side RCA cable either at the radio or at the amp? Maybe the RCA outer is touching something metal which will cause noise injection.
As for the FM, have you by chance tried that powered antenna amplifier on your in-fairing antenna.
According to the specs on the DB651 they should be able to handle the power with the way I had the gains set. I would say no to the 2 ohm speakers because then you'll only be able to use front outputs of the amp. We might want to look into the Titan II speakers which are HAT speakers
Running that amp, with dxi650's...same speaker. Sounds SUPER......BUT.... Amp also kills my FM reception. Unplug amp and hook up speakers, I get a TON of channels.....turn on amp, I get 1 or 2..........hmmmm. Is this just the nature of a class d amp? Or is there any solution besides mp3's? Not a deal breaker but I do still like my FM now and then.
No, I haven't tried that antenna yet, but I can't find that link you sent. Can you resend it please? As for the noise, it became apparent BEFORE I made any gain changes. Popped the speaker, swapped it out, and ignition noise from the right side upon start up. No noise on the other side. As for the amp, I'd just as soon run a different one if that's what it takes to have radio reception.
john and blue66. I would try something like this before giving up on the amp.
Hidden Antenna Radio Stereo Am FM Stealth Universal Vehicle Car Truck Motorcycle | eBay
http://www.crutchfield.com/p_068WPA2...1-Antenna.html
http://www.parts-express.com/pe/show...umber=265-5801
http://www.amazon.com/Hidden-Antenna...=5336075432-20
the major advantage is none of the EMI effects (FM interference)
the major disadvantage is THD (total harmonic distortion) numbers will increase because of the "rail-design" or "boosted rail design"
The Rockford Fosgate PBR300x4 and PBR300x2 are labeled as Class BR but in reality they are Class G/H amps.
I don't listen to FM at all so my choice would be the quality and clarity of sound vs FM
If you need to stay with a 4 ohm speaker, I'd highly recommend the Biketronics Titan II 6.5.
I haven't used my radio since my installation of the Soundstream & Polk MM's, so I guess I'd better go see if I'm having reception issues with the stock Harley head unit.
