Sony DSX-S310BTX and Zumo 660 issue...
Hey there,
Just got back from a 1700km trip with my new audio system and encountered a little bug a long the way.
The bluetooth connection between my zumo 660 and DSX-S310BTX works just fine for MP3 audio, however doesn't seem to work with spoken instructions from the GPS. The MP3 audio mutes while spoken instructions are supposedly being transmitted. Can anyone with the same set up please let me know if you encounter the same?
Will try resetting the radio, and clearing the Bluetooth on the Zuno next...
could it be that your phone or maybe a bluetooth headset is interfering with it? I agree that you should completely reset the bluetooth functionality as well as when you're pairing up your zumo to the head unit that no other bluetooth devices are within proximity. Had a similar issue when initially pairing mine where it showed as being paired but was getting nothing from my zumo 665. I walked over to my computer to do some reading and heard this noise and I'm like WTF... only to find out it was paired with my BT headset that was sitting on the counter 50 ft away.
Well.... no dice.
I reset the radio, and cleared the pairings in the zumo and re-paired the units together.
I get MP3 audio, but voice prompts still mute MP3 audio while a navigational direction is given by the zumo. Volume is at 100% for both Audio and Navigation on the Zumo,validated that audio output is set to bluetooth headset and not headphone, and have tried different voice files (Jack and Jill USA). I am obviously playing off the Bluetooth audio source on the Sony Deck.
Interestingly enough, the Sony deck shows that I am paired to both a audio source AND a mobile phone as per the icons on the screen. However I only paired the zumo after resetting the Sony.
Don't know where to go from here... Ultra, have you successfully paired these units and had voice prompts work for you?
Thanks for all your help.
Yes sir I have in the Bluetooth Audio mode.. So has MontyCop05.. Are you using a Garmin unit or a Roadtech unit?
Well.... no dice.
Originally was using the headphone jack output into the aux input of the harley radio.
As for your Sony.. if you want to shoot me your number in PM, when I get home later this afternoon I can give you a call and walk you through exactly what I'm doing when pairing mine up.
Will PM you.
