Hogtunes 4x Amp with Aftermarket Radio
Good day everyone.
First, I did some searching on this topic in the forum and didn't find much on it.
The issue: HK Rig is dead.
The fix: Replace
The question: Is the Hogtunes amp compatible with aftermarket radios?
I found one thread where it said yes, but no other info was posted.
Installed: H-D Boom Speakers, front and rear, Hogtunes NCA 40.4
If I cannot use the Hogtunes amp I'm guessing that I will need to replace the Boom speakers since they are 2ohms and aftermarket receivers are 4ohms, not to mention a replacement amp which will also be 4ohms. This sound right?
Thanks all and enjoy your ride.
- Whiskers
The fix: Replace
- Whiskers
Whiskersvtwin. Couple of things sir.
1.) instead of replacing the head unit you could send it to Iron Cross Audio for repairs which come with a warranty.
2.) simply replace the head unit with any aftermarket that suits your needs/tastes. If i'm not mistaken that HT amp doesn't have RCA inputs so just use the speaker outputs of the aftermarket head unit to feed the amp.
Good day everyone.
The fix: Replace
- Whiskers
The fix: Replace
- Whiskers
