New HD Head Unit from Jensen
no doubt and as stated previously it will be a welcomed upgrade to those running the stock head unit when the need arises for replacement at probably less than 1/4th the price of a stock head unit.
I don't see this in the specs I'm seeing. Still shows speaker outputs only.
"It’s also Sirius/XM ready, so you can add a SiriusXM tuner and antenna and control stations from the clear red and black face of the unit. And if the 50 watts x 4 channel isn’t enough, front and rear line-outs are included for adding additional amplifiers."
Second to last paragraph HERE Nutz
It also says "no" to overall dimensions and few other silly things. I'd bet that hasn't been updated or reviewed for accuracy in some time. I'd tend to agree with what the latest industry report is broadcasting.
Full manual with all the details. If my HK head unit dies again, I think this is what I'm going with...
http://www.asaelectronics.com/downlo...ers_manual.pdf
Interesting head unit. Bluetooth and USB connectivity. Depending on the pre-out voltage and price, this might be a nice little unit.
What I find interesting is that it says the speaker impedance is 4-8 ohms per channel. That's kinda messed up.
$500. Maybe cheaper somewhere else but I just did a quick search and found this:
http://www.directcycleparts.com/audi...y-p-12389.html
