Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Air vs Fuel
Old 05-21-2018, 10:41 PM
BiggCliff412's Avatar
BiggCliff412
BiggCliff412 is offline
Default Air vs Fuel
I have 1997 Dyna Wide Glide. Rebuilt CV carb. 45 pilot jet and 180 main. Shimmed stock needle.
I bought a Ness Big Sucker stage 2 and added V&H short shots as well. My trouble is when I have the air filter on, I get sneezing almost right as I open the throttle. If I take filter off and just keep backing plate attached to cylinders, I have no sneezing in the same scenario. Does not having the filter and it not sneezing as I open thw throttle mean Im needing more air? Or am I throwing too much fuel? I have had black plugs throughout my quest to rejet correctly from 45/46 and 170, 175, 180 mains.
Old 05-22-2018, 08:17 AM
marcodarq's Avatar
marcodarq
marcodarq is offline
how many turns out is your idle mixture screw?
m
Old 05-22-2018, 09:42 AM
BiggCliff412
I was about 1.5 turns out when i got stumble but I couldnt get it to stumble on the way out. I went over 3 turns with no stumble. I did adjustments with air cleaner on FWIW
Old 05-22-2018, 10:59 AM
BiggCliff412
Hmmm. Weird. Took 1 shim off the needle and ran around the neighborhood for 25 mins or so. These are the same plugs. The white one is this morning the other is before the ride.
Old 05-22-2018, 11:07 AM
BiggCliff412
Either I set the gapping light on both plugs at .37 instead of .40, the gap narrowed
kansasroadking
Exhaust System Topics
04-16-2015 01:39 PM
chuckw2
01-22-2012 07:57 AM
mulch63
Carburetor Related
10-20-2010 05:45 PM
run2bfit
07-06-2009 02:26 PM
SgtThump
12-02-2007 07:27 AM
Quick Reply: Air vs Fuel
