Best loc tight for crank case?
Received 47,791 Likes
Yes! Wire brush the bolts, clean the female threads and the male threads as best as possible, then spray with brake clean. Let dry or blow dry, then use blue loctite. If they are parts that gets hot, then you might need a heat resistant loctite. Also if you can, store the loctite in the fridge when not in use. It keeps allot longer. YD
