Varnished Carburetor Blues
I’m trying to rebuild a stock carb off a 01 Softail that’s been sitting for 10yrs. I have it all apart and except for a bunch of dried sludge and vanish, it’s looks pretty good. I was able to clean most of it, but how do I clean the ports? The manual says not to use any caustic cleaner and suggests Simple Green and hot water, which does absolutely nothing. So how do I get the crap out of the ports? If paper towel lint is an issue, I’m sure a bunch of varnish debris is fatal. I’m ready to move forward with a rebuild kit and new jets, just need some expert advice.
this is the after of a varnished carb, I was totally impressed. You can see the can in the background. Gunk.https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
I have no first-hand knowledge of this technique and am merely sharing what a mechanic told me regarding their newest and greatest carburetor cleaner. Evidently, the new machine super-heated the carb and allegedly burnt off all the crude with no elbow-grease needed. Perhaps such a method could be simulated in an oven with a "self-clean" feature. However, I suppose you would have to overlook the taste of petroleum products with your next meatloaf. Then again, maybe just stick with the suggestions offered by others. Good luck.
The following 2 users liked this post by 805dwg:
Dan89FLSTC (12-21-2018),
sailmotion (12-20-2018)
glad pinching pennies worked out. A buddy of mine used oven cleaner on his HD motor, what a permanent mess he made, but he saved money and labor.
