Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Carb slide vent hole repair?
Old 08-20-2014, 08:26 AM
br549A1's Avatar
br549A1
br549A1 is offline
Default Carb slide vent hole repair?
In the process of removing a dynojet kit I found that the slide hole was drilled to a #29 bit which was larger than a 1/8" bit. I sealed the hole with jb weld and drilled a new hole on the other side of the slide directly opposite. After reading a few comments on this I realized many redrilled right next to the old hole after it's sealed up.
Does the side of the slide he vent hole is drilled on matter at all? Looking at it I don't believe so, but wasn't sure as it's on the air cleaner side now instead of the side closer to the intake.
Thanks.
Old 08-22-2014, 04:10 PM
heybaylor's Avatar
heybaylor
heybaylor is offline
it is a vacuum hole, bigger causes the slide to open quicker. but will be just as open at a constant vacuum
wrong side might cause it to open slower as it is farther from the throttle plate ..
and more room to lose vacuum..
way overthinking .....how does it run ??
Old 08-22-2014, 06:34 PM
br549A1's Avatar
br549A1
br549A1 is offline
Originally Posted by heybaylor
it is a vacuum hole, bigger causes the slide to open quicker. but will be just as open at a constant vacuum wrong side might cause it to open slower as it is farther from the throttle plate .. and more room to lose vacuum.. way overthinking .....how does it run ??
That's why I'm asking. I developed a flat spot at 4500 rpms. Seems to me this shouldn't cause it but in the process of rejetting I thought I'd ask
Old 08-23-2014, 06:41 AM
GraemeR's Avatar
GraemeR
GraemeR is offline
just fill the new hole and redrill on the right side
Old 08-23-2014, 10:05 AM
br549A1's Avatar
br549A1
br549A1 is offline
Good idea. I just popped it off and drilled and filled. Thanks.
Zenmoto
Carburetor Related
02-11-2017 08:18 AM
das56170
EVO
12-28-2015 08:56 AM
Kevin01Z28
09-11-2015 03:20 PM
br549A1
EVO
09-19-2014 06:35 PM
t150vej
EVO
04-22-2009 06:57 PM
Quick Reply: Carb slide vent hole repair?
