Carb slide question
Old Aug 22, 2014 | 09:48 AM
br549A1's Avatar
br549A1
Asked this in the carb forum no responses. Reposting here for the evo experts.
In the process of removing a dynojet kit I found that the slide hole was drilled to a #29 bit which was larger than a 1/8" bit. I sealed the hole with jb weld and drilled a new hole on the other side of the slide directly opposite.
After reading a few comments on this I realized many redrilled right next to the old hole after it's sealed up. Does the side of the slide the vent hole is drilled on matter at all?
Looking at it I don't believe so, but wasn't sure as it's on the air cleaner side now instead of the side closer to the intake. Thanks.
Old Aug 22, 2014 | 05:27 PM
D_gyver's Avatar
D_gyver
no it doesn't matter
Old Aug 23, 2014 | 04:14 PM
Yankee Dog's Avatar
Yankee Dog
Yep! No difference, it's just a bleed hole and it won't know what side of the slide it is on. YD
Old Aug 23, 2014 | 08:41 PM
Kabear's Avatar
Kabear
http://www.cv-performance.com/harley...tuning-issues/
You might want to read paragraph 6 of this. Just in case you run into any trouble.
Old Sep 19, 2014 | 06:35 PM
br549A1's Avatar
br549A1
For anyone that considers this...where you drill the new hole is important. You won't know until you drop the plastic needle cap or retainer in, but you can block the new hole with one of the legs of the plastic cap if you don't check where it sits before you drill. I ended up buying a whole new slide because of this.
firemouth
Mar 23, 2019 05:52 PM
Zenmoto
Carburetor Related
Feb 11, 2017 08:18 AM
br549A1
Carburetor Related
Aug 23, 2014 10:05 AM
manesfesto
Jul 25, 2014 12:18 PM
BurgundyUltra06
Panhead
Mar 5, 2011 02:18 PM
