buffer
Old Feb 16, 2023 | 08:23 PM
coop creek's Avatar
coop creek
I have successfully polished the fairing a few times now with a Griots G8, 1" thick Griot's pads (or Buff and Shine pads) and Wolfgang polish.
I keep the pad from stalling by moving the rotating pad/machine fairly quickly back and forth, in an arc. It's a different technique and works fine for me.
Old Feb 16, 2023 | 08:27 PM
PureHybrid's Avatar
PureHybrid
Like was hinted at, use a smaller pad. 3in pad seems to work OK for me, but they do make adapters to run spot pads
Old Feb 17, 2023 | 03:04 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
In every case technique trumps product. If it is working you must be doing it right!
Old Feb 17, 2023 | 02:14 PM
eaglefan1's Avatar
eaglefan1
This is why my Flex is my favorite machine. Its heavy but it just works on any panel.
Old Feb 20, 2023 | 08:20 AM
bustert's Avatar
bustert
one with forced rotation is asking for burnt paint if one is not extremely careful.
the da/orbital is better and i use the variable speed one from HF and so far no issues, i use it to buff out lacquer on steel guitars i build.
one note: use one that is the proper size. there isn't much options in electric but pneumatic has more.
Old Feb 20, 2023 | 08:33 AM
Andy from Sandy
Technique trumps product. Never seen anyone burn paint. I have seen people go over and over the same spot and abrade through the clear coat though.
Old Feb 20, 2023 | 09:41 AM
eaglefan1's Avatar
eaglefan1
My Flex is forced rotation and its just as safe as a regular DA. Like Andy said, you almost have to try and burn thru the paint. Or somebody before you went crazy on it, then you work on it.
very few use a air powered da. When used its for small areas, never a whole car. As for guitars, never did one and dont plan on doing one
Old Feb 20, 2023 | 12:00 PM
CaffeineBuzz's Avatar
CaffeineBuzz
I was considering the Flex pe14-2-150....looks like you can do 3" pads
is that the one you work with, Eagle?
Old Feb 20, 2023 | 05:02 PM
eaglefan1's Avatar
eaglefan1
I have the 3401. Its a workhorse
Old Feb 21, 2023 | 07:47 AM
bustert's Avatar
bustert
big diff in a polisher and a buffer.
the polisher is forced rotation and yep it will peel the paint off be it clear or not.(burn meaning destroying the paint)
as was said, technique is paramount.
a buffer is designed to NOT leave swirl marks, hence multiple sweep direction. if you need rotation, easy to get with buffer, just ease up on pressure and if needed spot application hold at an angle.
how about a polisher that can pick up 190# person and chunk him across the room, been there done that!
also kick in type of buff/pad and cutting material.
