Scratch-X not cutting it - help
However, if you are in the know and have it in your heart to try and help me out, this is directed to you.
I have the infamous Vivid Black on my FXDC and the infamous swirls and scratches to go with it. I have never used anything but new micro-fiber cloths on the bike but I did used to use Meguiar's quick detailer on it - but only right after washing and drying the bike. I have no idea exactly how the scratches got there but I'm sure it's something I did unknowingly. Anyway, I have always washed my bike with S100 but now I use a blower to get the water off and then go back and clean the chrome with Windex and micro-fiber cloth. If the paint needs attention, I use HD glass and a NEW micro-fiber cloth.
To try to get the scratches out, I've tried HD scratch and swirl remover and Meguiars Scratch-X. Neither seems to do a thing with the scratches. I'd like to try buffing them out but I want to use something, hopefully, that is easy to get and not too expensive - like something off the shelf at Wally-World or AutoZone or something like that. I have a small handheld buffer that I used to use to get oxidation off of my boat. I haven't used it in several years but it's still around somewhere. I don't think it's variable speeds but it may have a low and a high setting - I'm not sure.
Can anyone recommend a compound and a method to try and get these scratches out? They don't seem deep at all but, as mentioned above, hand applied scratch removers don't seem to have any affect. I'm discouraged because Scratch-X says on the container that if it doesn't remove the scratches, they must be professionally removed by machine. So, based on that I'm not sure if I should be touching them any further. The last thing I want to do is make things worse.
I've seen several posts here that proclaim Scratch-X to be "the bomb" when it comes to these types of scratches, and it isn't working for me. So, I'm not sure wha the answer is.
Subscribing
I'm not a paint guy, but I would think the only way you can truly remove swirls is to have a brand new paint job.
Personally, I use the ride it, don't wash it method. Can't see any swirls on my bike.
Some good info here and at this forum also. http://www.autogeek.net
Keith@ec.rr.com
kwag37
