Zaino
If your nuts like me and dont want to use anything that is abrasive on your ride, this is the best stuff. It really works great. And im not affiliated with them in any way. Their product is very popular in the chevy circle, mostly the newer the ls1, ls2 vetts, birds and camaros.
Very easy to use, and it smells awesome. Does not contain anything that is abrasive like curnaba (sp?) does. However this is a trick to using it, so it takes a while to get into the hang of using it if your used to globing on loads of wax and buffing till your arm falls off.
Waxes we use are Victoria, PS21 Concours (S100), Griots, Pinnacle Souveran, Collinite, FK1 Pink Wax, Blackfire and Poorboys Natty and also various polymer/ carnauba blends form Duragloss, Smartwax and XMT.
Zaino Z2 is a sealant..Z5 is a sealant with fillers.....ZPC is a polish.
Z2 and Z5 are old stock as these have been updated to Z2 Pro and Z5 Pro.
NOTE: Zaino Z-PC Fusion IS ABRASIVE and should only be used when necessary. Z-PC Fusion is not intended for frequent use.
For years, visual imperfections such as swirl marks, scuffs, scratches and buffer holograms were the scourge of perfectionists everywhere. They infected vehicles without any discrimination - show cars, daily drivers, imports, domestics and custom vehicles all suffered. But worry no more - Zaino, the world's leader in paint care technology, has the antidote for all of your paint ailments: Zaino Fusion Dual Action Paint Cleaner Swirl Remover ("Z-PC").
Featuring the world's first (and only) true, self-dissolving, fused tri-particulate, diminishing abrasive system, Zaino Z-PC Fusion is just what the paint doctor ordered for your vehicle. Whether your paint is suffering from spider-webbing, minor scuffmarks, or a fully developed case of the swirls, Zaino Z-PC Fusion has the cure. And best of all, it works equally well when used by hand or machine, making it as versatile as it is effective!
Thanks to Zaino's advanced, fused tri-particulate, self-dissolving diminishing abrasive system, swirls and other defects are safely removed from your vehicle's paint. The ultra-intelligent abrasives gently and carefully knockdown high spots on your car to reveal an extremely smooth, super-reflective, mile-deep shine. Swirl marks and other blemishes will literally disappear before your eyes, and they'll stay away - Zaino Z-PC Fusion contains no fillers or oils.
With Zaino Z-PC Fusion, you'll be amazed by how deep, glossy, clean, and blemish-free your paint looks, and you'll love the compatibility that it provides. Unlike other paint prep products that are typically loaded with cheap oils and fillers, the water-based formula of Zaino Z-PC Fusion requires no washing afterward - just apply and remove Zaino Z-PC Fusion and go straight to applying your favorite Zaino protectant. Further, there's virtually no effort required to apply and remove Zaino Z-PC Fusion. Just wipe it on, work it in (either by hand or machine) and wipe it off.
Zaino Z-PC Fusion is perfect for any type of paint - from single-stage paints to clear-coated finishes to gel-coats, Zaino Z-PC Fusion will bring out the best in your paint. Metallics will sparkle! Pearls will pop! Reds will scream, "Pull me over," and your black paint will never have looked so smooth. It's perfect for domestic cars, European cars and imports. So whether you're driving a super-exotic performance car or just running the kids around town, be confident that no other paint cleaner is as advanced, effective and easy to use as Zaino Z-PC Fusion is.
If I ever get anything that its paint is in bad enough shape to need a swirl remover or cleaner with the great experience I have had with Zaino I wouldnt hesitate to use Z-PC
[quote]ORIGINAL: 3Dog
Z2 pro and Z5 pro are both polishes says it right on the bottle! Z-PC says it is a swirl remover and cleaner! That is not a polish.
Bottom line is....If it works for you , use it.
