Smallest Blinker ??
Looking to replace the rather large stock front and rear blinkers with something much much smaller... I'm looking at the Kuryakyn LED silver bullets but I'd like something even smaller if possible...... sugestions please ....
Thanks
Thanks
There is an endless amount of them. I wanted to go this route as well but was told that I would need to purchase a relay that would draw the same ampage as the OEM ones. This relay is supposed to be around $100 bucks. Any one heard of this, any way around it?
These arent the smallest, but smaller than stock..........................J&P Cycles.............LO.........
[IMG]local://upfiles/19303/46C5D808F78C4948ACC1FEAFD046F5A5.jpg[/IMG]
I bought small oval marker lights. Mounted them hooked them up and bought nothing extra. They were like 30-35 dollars. I've heard some bikes you need the load equalizer and some you don't. I didn't. 06 bob.
ORIGINAL: Noride
So you can either change out the flasher that is compatible or add a resistor across the bulb to draw the current the flasher wants to see.
http://autolumination.com/equalizers.htm scroll down the page.
http://www.customled.com/PRODUCTS/TH..._equalizer.htm
http://www.bigbearchoppers.com/parts...t_blinkers.htm
i dont think you can get small thenthat ...................
.....................................unless you drill holes in the frame and flush mount LEDs into it...........hmmmmm thats not a bad idea if you can run wire through the rear end but i think that part of the frame is sold cast , not hollow in the middle. anybody know?
ORIGINAL: baxter
there dosent seem to be too much info on them (size, fittment)
ORIGINAL: baxter
i dont think you can get small then that ...................
Thanks,
Scott
