'01 Low rider gauge/tank cover trim
Old 11-24-2014, 08:13 AM
DamienBlade's Avatar
DamienBlade
DamienBlade is offline
Default '01 Low rider gauge/tank cover trim
I have a '01 Low rider and the chrome tank cover + gauges have rubber trim around them.
The trims have started to erode and it's time to replace them.
Are there actual spare parts for these or should I just look for random trims from a local hardware store?
Old 11-24-2014, 08:57 AM
fwb35's Avatar
fwb35
fwb35 is offline
I have an 2000 low rider, the trim piece on the tank is black with rubber edge trim, it keeps coming off when I am going down the road, previous owner tried glueing it back on, still comes off, any remedies for this problem? Are you having the same problem?
Old 11-24-2014, 12:05 PM
AmericanLowRider's Avatar
AmericanLowRider
AmericanLowRider is offline
Replacement is about $3 at Harley. I superglued mine to stay on. Still holding strong after 3 years.
Old 11-24-2014, 01:10 PM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
HYere's the p/n: 67119-95 TRIM, CONSOLE
Old 11-25-2014, 08:21 AM
DamienBlade
Yeah I have exactly the same problem with the previous owner's gluing and all.
I removed the tank cover and removed the trim completely so I can start fresh because the gluing looked sloppy.
Is this for the tank cover or the gauges? Both have rubber strips around them and I need to renew both. Couldn't find decent pictures with that umber.
Old 11-25-2014, 12:51 PM
FXD2003Rider
67119-95 is for the console indeed. For the gauges you'll need 92061-95 GASKET, INSTRUMENT MOUNTING.
Check out the parts diagrams at Ronnie's...
Old 12-04-2014, 11:50 AM
DamienBlade
Thanks, FXD2003Rider.
However I also managed to find another quick way of fixing this problem - no gluing needed!
Guys, if your rubber strips look bad, forget messy glue fixes, just rip them off and buy this stuff..
http://aijaa.com/yLlDmK
(Link is safe and contains an image)
On the left you can see an hour's work of me trying to glue a new rubber strip in place with contact glue..
On the right you can see a self-adhesive strip that I put in place within 5 seconds, with no glue at all. It just snaps on there and stays in shape. In my opinion it even looks better than the factory version.
I'm not sure what that material is called, but they use that stuff in car doors.
Old 12-06-2014, 07:40 AM
DamienBlade
I just checked a dozen online stores for these parts and they all say they won't ship outside the U.S.
Wow, that's weird.
I live in Finland, Europe and it seems there's no way to get these original parts shipped here.
The trims I put on in my last post don't look good on the bike so I'm looking for the originals now.
Old 12-10-2014, 12:24 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,238 Likes on 1,814 Posts
FYI, If you're looking for the rubber moulding for the Tank Trim Panel shown in attached photo, the part# is 61648-85
Attached Thumbnails '01 Low rider gauge/tank cover trim-tank-panel.jpg
Old 12-10-2014, 07:50 AM
fwb35's Avatar
fwb35
fwb35 is offline
Any sources on where to get that trim?
sioux565
07-18-2011 06:34 PM
Tarponrod
05-12-2009 08:23 PM
sddyna
02-03-2009 10:02 PM
Electra1
01-02-2009 08:30 PM
LOTHAR
10-19-2006 06:19 PM
Quick Reply: '01 Low rider gauge/tank cover trim
