What did you do to your Dyna today?
  #12481
Old 07-03-2019, 02:15 PM
SixDD's Avatar
SixDD
SixDD is offline
Location: Depends on who wants to know.........and why.
Received 1,901 Likes on 1,109 Posts
Today so far I am temporarily placing the new emblems to find the sweet spot. this is obviously off:
  #12482
Old 07-03-2019, 06:14 PM
ThePaintPirate's Avatar
ThePaintPirate
ThePaintPirate is offline
Received 1,503 Likes on 788 Posts
Made the mistake of test riding a new Scorched Orange Road King Special. Didn't buy it of course but for $21k and $16k for the Dyna out the door, it's tempting.
  #12483
Old 07-04-2019, 10:58 AM
John CC's Avatar
John CC
John CC is offline
Originally Posted by SixDD
the kind I did not like were the "stat-O" I think they are called.
There are two products, Lock-o-seal and Stat-o-seal. Stat-o-seal is one piece and Lock-o-seal the rubber is not bonded to the metal. They both work well when the hardware is correct. The only reason I can think of for the rubber to extrude out the side is if the OD of the banjo bolt is too large for the seal. There should be space for the rubber to compress into and make the seal.
  #12484
Old 07-04-2019, 05:25 PM
fxdup's Avatar
fxdup
fxdup is offline
I checked the oil. Still full.
  #12485
Old 07-04-2019, 10:48 PM
Mallard Slayer's Avatar
Mallard Slayer
Mallard Slayer is online now
Received 4,159 Likes on 1,125 Posts
Was going to take a little ride but had no electrical found loose ground wire to battery tightened it up and went and jeopardised my license for a couple hours!! Damn these dynas are fun!!
fxdup (07-05-2019)
  #12486
Old 07-05-2019, 12:24 AM
ADR's Avatar
ADR
ADR is offline
Happy 4th. Make Independence day, everyday!
  #12487
Old 07-05-2019, 07:53 AM
the_huber_show's Avatar
the_huber_show
the_huber_show is offline
I replaced my gasket on my front brake master cylinder yesterday before a nice couple hour ride. Old gasket looked fine but something was off as the new one isn't leaking so that's a plus
  #12488
Old 07-05-2019, 08:51 AM
ABQ-Jammer's Avatar
ABQ-Jammer
ABQ-Jammer is offline
Received 4,753 Likes on 2,317 Posts
Went to check out a pair of Heritage style LeatherLyke saddlebags, since one of mine fell off on a long ride, and got demolished by other vehicles coming behind me, and decided to get them for $60 (haggled down from $75). When I got home, and tried to install them, though, the mounting bracket wouldn't bolt up with the stock bolts (PO had them mounted on VTX1800, so bolt patter different), so I had to go to the hardware store to get the right ones. Hopefully, I can get them cleaned up and mounted tonight, before going on another ride tomorrow. Will have to have the bolts come from the inside of the fender out, to go onto the mount pieces that fit into the bags to lock on, but will probably have to flip the inside bracket around, with threaded hole at the rear instead of the front, since mounting bolts are very different sizes and threads (1 is really small - 10/32, and the other is big, but 1.5Xs more threads per inch than stock).
  #12489
Old 07-05-2019, 02:27 PM
beanoboy's Avatar
beanoboy
beanoboy is offline
That's a cool bike ! What year is it ?
  #12490
Old 07-05-2019, 02:40 PM
scott_0's Avatar
scott_0
scott_0 is online now
Received 1,938 Likes on 1,028 Posts
added the chopped fender light, nice little subtle mod
The following 2 users liked this post by scott_0:
fxdup (07-07-2019), Wormjello (07-15-2019)
Quick Reply: What did you do to your Dyna today?
